Haas CM-1 Compact Mill Vertical Machining Centre
Haas CM-1 Compact Mill Specifications
Travels S.A.E. Metric
X Axis 12 " 305 mm
Y Axis 10 " 254 mm
Z Axis 12 " 305 mm
Spindle Nose to Table (~ max) 15.25 " 387.4 mm
Spindle Nose to Table (~ min) 3.25 " 82.6 mm
Table S.A.E. Metric
Length 20 " 508 mm
Width 10 " 254 mm
T-Slot Width 0.438 " 11.13 mm
T-Slot Center Distance 3.375 " 85.73 mm
Number of Std T-Slots 3 3
Max Weight on Table (evenly distributed) 150 lb 68 kg
Spindle S.A.E. Metric
Max Rating 5 hp 3.7 kW
Max Speed 30000 rpm 30000 rpm
Max Torque 8 ft-lb @ 3000 rpm 10.8 Nm @ 3000 rpm
Drive System Direct Speed, Belt Drive Direct Speed, Belt Drive
Taper ISO 20 ISO 20
Bearing Lubrication Air / Oil Injection Air / Oil Injection
Cooling Air Air
Spindle (opt) S.A.E. Metric
Max Speed 50000 rpm 50000 rpm
Max Torque 3.7 ft-lb @ 3700 rpm 5.0 Nm @ 3700 rpm
Drive System Direct Speed Belt Drive Direct Speed Belt Drive
Taper ISO 20 ISO 20
Feedrates S.A.E. Metric
Rapids on X 757 in/min 19.2 m/min
Rapids on Y 757 in/min 19.2 m/min
Rapids on Z 757 in/min 19.2 m/min
Max Cutting 500 in/min 12.7 m/min
Axis Motors S.A.E. Metric
Max Thrust X 1149 lb 5111 N
Max Thrust Y 1149 lb 5111 N
Max Thrust Z 1149 lb 5111 N
Tool Changer S.A.E. Metric
Type Carousel Carousel
Capacity 20 20
Max Tool Diameter (full) 2.3 " 58 mm
Max Tool Weight 5 lb 2.3 kg
Tool-to-Tool (avg) 3.2 sec 3.2 sec
General S.A.E. Metric
Air Required 1 scfm, 100 psi 28 L/min, 2.8-4.8 bar
Coolant Capacity 13 gal 49 L
