The Best-Value CNC Turning Centres in the Industry
Rigid, high-performance CNC lathes with a wide selection of available options for every workshop.
The Haas ST Series high-performance turning centres were designed from the ground up. The CNC turning centres provide setup flexibility, extreme rigidity, and high thermal stability.
The ST-30 CNC lathe has a medium footprint, and provides a generous work envelope. This machine offers the best performance for the money – the best value – in its class.
- Medium footprint
- Generous work envelope
- Ideal for high-volume, high-production environments
CNC Lathe; 15″ x 32.5″ (381 x 826 mm) max capacity, 3.0″ (76 mm) bar, 31.75″ (806 mm) swing, 30 hp (22.4 kW) vector drive, 3400 rpm, A2-6 spindle,10″ (254 mm) chuck, 12-station bolt-on turret, 15″ colour LCD monitor, memory lock keyswitch, USB port and rigid tapping. Standard toolholder kit included with BOT or Hybrid turret. The Haas Bar Feeder is not compatible with the optional gear-drive spindle.
Haas Bar Feeder
Automate Your CNC Turning Centre Part Production
The Bar Feeder is a simple and affordable way to automate production on Haas turning centres to boost productivity. It is designed and built exclusively for Haas CNC turning centres and connects directly to the Haas control. An innovative rollaway design provides easy access to the rear of the lathe spindle for quick liner adapter and spindle liner changes.
The ST-30 CNC turning centre at Work
Turning 1018 steel, drilling a 3.5″, and threading a straight Acme thread. Great performance, no chatter, and beautiful finishes. Live tooling helps make this part complete; no need for a transfer to a milling machine for a few simple holes.
