Haas DM-2 Drill and Mill Centre
Haas DM-2 Specifications
X Axis 28 "  711 mm
Z Axis 15.5 "  394 mm
TABLE S.A.E. METRIC
Length 34 "  864 mm
Width 15 "  381 mm
Max Weight on Table (evenly distributed) 250 lb  113 kg
Max Speed 15,000 rpm  15000 rpm
Max Torque 46 ft-lb @ 1700 rpm  62 Nm @ 1700 rpm
Drive System Inline Direct Drive   Inline Direct Drive
Taper CT40 or BT40   CT40 or BT40
Bearing Lubrication Air/Oil   Air/Oil
Cooling Air   Air
TAPPING S.A.E. METRIC
Max Tapping Speed 5000 rpm  5000 rpm
Max Tap Size (aluminum) 1/2 x 13   M12 x 1.75 mm
Rapids on X 2400 in/min  61.0 m/min
Rapids on Y 2400 in/min  61.0 m/min
Rapids on Z 2400 in/min  61.0 m/min
Max Cutting 1200 in/min  30.5 m/min
Max Thrust X 2550 lb  11343 N
Max Thrust Y 2550 lb  11343 N
Max Thrust Z 4200 lb  18683 N
Capacity 18+1   18+1
Max Tool Diameter 2.5 "  64 mm
Max Tool Diameter (adjacent empty) 2.5 "  64 mm
Max Tool Length 7.0 "  178 mm
Chip-to-Chip (avg) 1.8 sec  1.8 sec
Coolant Capacity 45 gal  170 L
