Haas DS-30 Dual Spindle Turning Centre
Haas DS-30 Specifications
Over Second Spindle 21.75 "  552 mm
Max Cutting Diameter 18.0 "  457 mm
Max Cutting Length 26 "  660 mm
Bar Capacity 2.0 "  51 mm
X Axis 12.5 "  318 mm
Z Axis 26 "  660 mm
Rapids on X 945 in/min  24.0 m/min
Rapids on Z 945 in/min  24.0 m/min
Max Thrust Z 5100 lb  22686 N
Max Torque 300 ft-lb @ 500 rpm  407 Nm @ 500 rpm
Spindle Bore ø 3.50 "  88.9 mm
MAIN SPINDLE C AXIS S.A.E. Metric
Positioning (±) 0.01 °  0.01 °
Brake Clamp Force 1000 lb  4448 N
Control Type Interpolated Motion & Positioning   Interpolated Motion & Positioning
SECONDARY SPINDLE S.A.E. Metric
Max Rating 20 hp  14.9 kW
Max Torque 135 ft-lb @ 700 rpm  183 Nm @ 700 rpm
Spindle Nose A2-5   A2-5
SECONDARY SPINDLE POSITIONING S.A.E. Metric
Brake Clamp Force 500 lb  2224 N
Brake Diameter 7 "  178 mm
Control Type Positioning Only   Positioning Only
OD vs ID Tools Hybrid 6 BOT/6 VDI   Hybrid 6 BOT/6 VDI
Click for CNC machines
