Haas DS-30SS Super Speed Dual Spindle Turning Centre
Haas DS-30SS Specifications
Over Second Spindle 21.75 "  552 mm
Max Cutting Diameter 16.0 "  406 mm
Max Cutting Length 26 "  660 mm
Bar Capacity 2.0 "  51 mm
X Axis 12.5 "  318 mm
Z Axis 26 "  660 mm
Rapids on X 945 in/min  24.0 m/min
Max Thrust Z 4050 lb  18015 N
Max Speed 4800 rpm  4800 rpm
Max Torque 275 ft-lb @ 600  rpm  373 Nm @ 600 rpm
MAIN SPINDLE C AXIS S.A.E. Metric
Positioning (±) 0.01 °  0.01 °
Brake Clamp Force 1000 lb  4448 N
Control Type Interpolated Motion & Positioning   Interpolated Motion & Positioning
SECONDARY SPINDLE S.A.E. Metric
Max Rating 20 hp  14.9 kW
Max Torque 110 ft-lb @ 700 rpm  149 Nm @ 700 rpm
Spindle Nose A2-5   A2-5
Max Cutting Diameter 18 "  457 mm
Max Cutting Length 23 "  584 mm
Spindle Bore ø 2.44 "  61.9 mm
SECONDARY SPINDLE POSITIONING S.A.E. Metric
Brake Clamp Force 500 lb  2224 N
Brake Diameter 7 "  178 mm
Control Type Positioning Only    Positioning Only
Number of Tools 24 Stations   24 Stations
OD vs ID Tools Hybrid 12 BOT/12 VDI   Hybrid 12 BOT/12 VDI
