Haas EC-1600ZT Horizontal Machining Centre
Haas EC-1600ZT Specifications
EC-1600
X Axis 64 "  1626 mm
Y Axis 50 "  1270 mm
Z Axis 32 "  1016 mm
Length 64 "  1626 mm
Width 36 "  914 mm
Max Weight on Table (evenly distributed) 10000 lb  4536 kg
Max Speed 6000  rpm  6000 rpm
Max Torque 450 ft-lb @ 500 rpm  610 Nm @ 500 rpm
Drive System 2-speed geared head   2-speed geared head
Taper CT or BT 50   CT or BT 50
SPINDLE (OPT) S.A.E. Metric
Max Speed 10000 rpm  10000 rpm
Max Torque 250 ft-lb @ 600 rpm  339 Nm @ 600 rpm
4TH AXIS (OPT) S.A.E. Metric
Max Rating 5.0 hp  3.7 kW
Table 64" x 32"   1626 x 813 mm
Platter Diameter 30 "  762 mm
Max Weight on Platter 10000 lb  4536 kg
Rotational Torque (continuous) 2000 ft-lb  2712 Nm
Gear Ratio 500:1   500:1
Brake Torque 4000 ft-lb  5423 Nm
Min Resolution 0.001 °  0.001 °
Indexing Accuracy ± 30 arc-sec   ± 30 arc-sec
Repeatability 15 arc-sec   15 arc-sec
Rapids on X 540 in/min  13.7 m/min
Rapids on Y 540 in/min  13.7 m/min
Rapids on Z 540 in/min  13.7 m/min
Max Thrust X 5600 lb  24910 N
Max Thrust Z 7500 lb  33362 N
Capacity 30+1   30+1
Max Tool Diameter (adjacent empty) 10 "  254 mm
Max Tool Diameter (full) 4 "  102 mm
Max Tool Length (from gage line) 20 "  508 mm
Max Tool Weight 30 lb  13.6 kg
Tool-to-Tool (avg) 10.3 sec  10.3 sec
Chip-to-Chip (avg) 12.6 sec  12.6 sec
Air Required 9 scfm, 100 psi  255 L/min, 6.9 bar
Machine Weight 30000 lb  13608 kg
