Haas GR-712 Gantry Router
Haas GR-712 Specifications
X Axis 145 "  3683 mm
Y Axis 85 "  2159 mm
Z Axis 11 "  279 mm
Spindle Nose to Table (~ max) 13.5 "  343 mm
Spindle Nose to Table (~ min) 2.5 "  64 mm
TABLE S.A.E. METRIC
Length 144 "  3658 mm
Width 72 "  1829 mm
Thickness 1 "  25.4 mm
Between Columns 86 "  2184 mm
Max Weight on Table (evenly distributed) 6000 lb  2722 kg
Max Speed 10000 rpm  10000 rpm
Max Torque 17 ft-lb @ 4600 rpm  23 Nm @ 4600 rpm
Rapids on X 800 in/min  20.3 m/min
Rapids on Y 2100 in/min  53.3 m/min
Rapids on Z 1100 in/min  27.9 m/min
Max Cutting 800 in/min  20.3 m/min
Max Thrust X 2520 lb  11210 N
Max Thrust Y 1020 lb  4537 N
Max Thrust Z 2050 lb  9119 N
Capacity 10    10
