Haas HA5C Indexing UnitHaas CNC machine tools, CNC mills and CNC lathes
Haas HA5C Specifications
Max Speed 0.001 to 410 °/sec  0.001 to 410 °/sec
Max Torque 60 ft-lb  81 Nm
Nose Thread 2 3/16 - 10 "
Runout Max 0.0004 "  0.010 mm
Backlash 40 arc-sec   40 arc-sec
Center Height 4.000 ± 0.001 "  101.60 ± 0.03 mm
Gear Ratio 60:1   60:1
Collet size std 5C 1/64 - 1 1/16 "  std 5C 0.4 - 27 mm
Accuracy (±) 30 arc-sec   30 arc-sec
Worm Gear Dia 2.8 "  71 mm
Power Requirement 115 VAC ±5% @ 10 A   115 VAC ±5% @ 10 A
Duty Cycle (w/o tailstock) 75 % @ full speed  75 % @ full speed
Rotary Head 48  lb  21.8 kg
Brushless Control – 1-Axis 14.2 lb  6.4 kg
Click for CNC machines
