Haas HA5C-4 Quad Spindle Indexing UnitHaas CNC machine tools, CNC mills and CNC lathes
Haas HA5C-4 Specifications
Number 4   4
Max Speed 0.001 to 200 °/sec  0.001 to 200 °/sec
Max Torque 25 ft-lb  34 Nm
Nose Thread 2 3/16 - 10 "
Runout Max 0.0004 "  0.010 mm
Backlash 50 arc-sec   50 arc-sec
Center Height 5.875 ± 0.002 "  149.23 ± 0.05 mm
Gear Ratio 60:1   60:1
Collet size std 5C 1/64 - 1 1/16 "  std 5C 0.4 - 27 mm
Accuracy (±) 60 arc-sec   60 arc-sec
Worm Gear Dia 2.8 "  71 mm
Power Requirement 115 VAC ±5% @ 15 A   115 VAC ±5% @ 15 A
Duty Cycle (w/o tailstock) 75 % @ full speed  75 % @ full speed
Rotary Head 225 lb  102.1 kg
Brushless Control – 1-Axis 14.2  lb  6.4 kg
