Haas HRC-160 Roller Cam Rotary Table SpecificationsHaas CNC machine tools, CNC mills and CNC lathes
Platter S.A.E. Metric
Diameter 6.3 " 160 mm
Number of Std T-Slots 6 @ 60° 6 @ 60°
Through Bore 1.500 " 38.1
Center Height 5.000" ±0.001 127.00 mm ±0.03
Min Bolt Circle 3.92 " 99.6 mm
Spindle S.A.E. Metric
Max Speed 830 °/sec 830 °/sec
Max Torque 108 ft-lb 146 Nm
Drive System Roller Cam Roller Cam
Gear Ratio 36:1 36:1
Brake Torque @ 100 psi/6.9 bar 96 ft-lb 130 Nm
Indexing S.A.E. Metric
Max Rotation/Step 999.999 ° 999.999 °
Resolution 0.001 ° 0.001 °
Accuracy (±) 30 arc-sec 30 arc-sec
Repeatability 4 arc-sec 4 arc-sec
Motor S.A.E. Metric
Type High-Torque Brushless Servo High-Torque Brushless Servo
General S.A.E. Metric
Air Pressure Max 150 psi 10.3 bar
Weight S.A.E. Metric
Table 110 lb 50 kg
