Haas HRC-210 Roller Cam Rotary Table SpecificationsHaas CNC machine tools, CNC mills and CNC lathes
Diameter 8.3 "  210 mm
Pilot Bore Dia 2.0000" (+0.0005" -0) x 1.91" deep   50.800 (+0.013 -0) x 48.5 deep mm
Through Bore 1.77 "  45 mm
Min Bolt Circle 4.37 "  111 mm
Max Speed 830 °/sec  830 °/sec
Max Torque 110 ft-lb  149 Nm
Drive System Roller Cam   Roller Cam
Center Height 6.000 ± 0.001 "  152.40 ± 0.03 mm
Gear Ratio 36:1    36:1
Brake Torque @ 100 psi/6.9 bar 134 ft-lb  182 Nm
Accuracy (±) 30 arc-sec   30 arc-sec
Repeatability 4 arc-sec   4 arc-sec
MOTOR S.A.E. METRIC
Type Brushless Servo   Brushless Servo
Duty Cycle full/low speed 50/100  %  50/100 %
Table 157 lb  71.2 kg
