Haas Magazine
Haas HRT-160 Rotary TableHaas CNC machine tools, CNC mills and CNC lathes
Diameter 6.3 "  160 mm
Max Speed 0.001 to 130 °/sec  0.001 to 130 °/sec
Max Torque 150 ft-lb  203 Nm
Through Bore 1.5000 (+0.0005 -0) "  38.100(+0.013 -0) mm
Center Height 5.000 ± 0.001 "  127.00 ± 0.03 mm
Gear Ratio 63:1    63:1
Timing 2:1   2:1
Brake Torque @ 100 psi/6.9 bar 100 ft-lb  136 Nm
Worm Gear Dia 4.7 "  119 mm
Power Requirement 115 VAC ± 10% @ 15 A   115 VAC ± 10% @ 15 A
Duty Cycle (w/o tailstock) 50/100 %  50/100 %
Table 90 lb  40.8 kg
