Haas HRT-160SP Rotary Table SpecificationsHaas CNC machine tools, CNC mills and CNC lathes
Diameter 6.3 "  160 mm
Max Speed 0.001 to 130 °/sec  0.001 to 130 °/sec
Max Torque 150 ft-lb  203 Nm
Pilot Bore Dia 1.500 "  38.10 mm
Pilot Bore Depth 6.00 "  152.4 mm
Center Height 5.000 ± 0.001 "  127.00 ± 0.03 mm
Gear Ratio 63:1    63:1
Brake Torque @ 100 psi/6.9 bar 100 ft-lb  136 Nm
Worm Gear Dia 4.70 "  119.4 mm
Power Requirement 115 VAC ± 10% @ 15 A   115 VAC ± 10% @ 15 A
Table 90 lb  40.8 kg
