Haas HRT-210-2 Rotary Table SpecificationsHaas CNC machine tools, CNC mills and CNC lathes
Diameter 8.30 "  210 mm
Number 2   2
Max Speed 0.001 to 60 °/sec  0.001 to 60 °/sec
Max Torque 170 ft-lb  230 Nm
Through Bore 2.0000 (+0.0005 -0) "  50.800 (+0.013 -0) mm
Center Height 7.750 ± 0.001 "  196.85 ± 0.03 mm
Gear Ratio 90:1    90:1
Worm Gear Dia 6.30 "  160.0 mm
Power Requirement 115 VAC ± 10% @ 15 A   115 VAC ± 10% @ 15 A
Brushless Control 14.2  lb  6.4 kg
Table 355  lb  161.0 kg
