Haas HRT-210SP Rotary Table SpecificationsHaas CNC machine tools, CNC mills and CNC lathes
Diameter 8.3 "  210 mm
Max Speed 0.001 to 100 °/sec  0.001 to 100 °/sec
Max Torque 210 ft-lb  285 Nm
Pilot Bore Dia 2.0000" (+0.0005" -0) "  50.800 (+0.013 -0) mm
Pilot Bore Depth 7.00 "  177.8 mm
Center Height 6.000 ± 0.001 "  152.40 ± 0.03 mm
Gear Ratio 63:1    63:1
Worm Gear Dia 6.3 "  160 mm
Power Requirement 115 VAC ± 10% @ 15 A   115 VAC ± 10% @ 15 A
Air Pressure Max 1210 psi  8.3 bar
Table 90 lb  40.8 kg
