Haas HRT-310 Rotary Table SpecificationsHaas CNC machine tools, CNC mills and CNC lathes
Diameter 12.2 "  310 mm
Max Speed 0.001 to 75 °/sec  0.001 to 75 °/sec
Max Torque 300 ft-lb  407 Nm
Runout Max 0.0010 "  0.025 mm
Center Height 9.000 ± 0.001 "  228.60 ± 0.03 mm
Gear Ratio 72:1    72:1
Spindle Bore ø 3.250 x 9.875 "  82.55 x 250.83 mm
Brake Torque @ 100 psi/6.9 bar 500 ft-lb  678 Nm
Worm Gear Dia 9.4 "  235 mm
Power Requirement 115 ± 10% VAC @ 15 A    115 ± 10% VAC @ 15 A
Table 435 lb  197.3 kg
