Haas Magazine
Haas HRT-450 Rotary Table SpecificationsHaas CNC machine tools, CNC mills and CNC lathes
Diameter 17.7 "  450 mm
Max Speed 0.001 to 50 °/sec  0.001 to 50 °/sec
Max Torque 400 ft-lb  542 Nm
Runout Max 0.0015 "  0.038 mm
Center Height 11.500 ± 0.001 "  292.10 ± 0.03 mm
Gear Ratio 72:1    72:1
Timing 3:1    3:1
Brake Torque @ 100 psi/6.9 bar 1800 ft-lb  2440 Nm
Worm Gear Dia 13.5 "  343 mm
Power Requirement 115 ± 5% VAC @ 15 A    115 ± 5% VAC @ 15 A
Table 850 lb  385 kg
