Haas HRT-600 Rotary Table SpecificationsHaas CNC machine tools, CNC mills and CNC lathes
Diameter 23.6 "  600 mm
Max Speed 0.001 to 50 °/sec  0.001 to 50 °/sec
Max Torque 450 ft-lb  610 Nm
Runout Max 0.0015 "  0.038 mm
Center Height 14.500 ± 0.001 "  368.30 ± 0.03 mm
Gear Ratio 72:1    72:1
Timing 3.5:1    3.5:1
Brake Torque @ 100 psi/6.9 bar 1800 ft-lb  2440 Nm
Worm Gear Dia 13.5 "  343 mm
Power Requirement 115 ± 5% VAC @ 15 A    115 ± 5% VAC @ 15 A
Duty Cycle full/low speed 50/100  %  50/100 %
Table 1475 lb  669 kg
