Haas HRT-A6 Rotary Table SpecificationsHaas CNC machine tools, CNC mills and CNC lathes
Max Speed 0.001 to 100 °/sec  0.001 to 100 °/sec
Max Torque 210 ft-lb  285 Nm
Center Height 6.000 ± 0.001 "  152.40 ± 0.03 mm
Gear Ratio 90:1    90:1
Tooling A1-6 Spindle   A1-6 Spindle
Worm Gear Dia 6.30 "  160.0 mm
Power Requirement 115 ± 10% VAC @ 15 A    115 ± 10% VAC @ 15 A
Duty Cycle full/low speed 50/100  %  50/100 %
Brushless Control 14.2  lb  6.4 kg
Table 165  lb  74.8 kg
