Haas Mini Mill Vertical Machining Centre
Haas Mini Mill Specifications
X Axis 16 "  406 mm
Y Axis 12 "  305 mm
Z Axis 10 "  254 mm
Spindle Nose to Table (~ min) 4.0 "  102 mm
Spindle Nose to Table (~ max) 14.0 "  356 mm
Length 36 "  914 mm
Length (Work Area) 28.75 "  730 mm
Width 12 "  305 mm
T-Slot Center Distance 4.33 "  110.0 mm
Max Weight on Table (evenly distributed) 500 lb  227 kg
Max Torque 33 ft-lb @ 1200 rpm  45 Nm @ 1200 rpm
Bearing Lubrication Grease Packed   Grease Packed
Rapids on X 600 in/min  15.2 m/min
Rapids on Y 600 in/min  15.2 m/min
Rapids on Z 600 in/min  15.2 m/min
Capacity 10   10
Tool-to-Tool (avg) 3.6 sec  3.6 sec
Chip-to-Chip (avg) 5.0 sec  5.0 sec
Coolant Capacity 24 gal  91 L
Machine Weight 3400 lb  1542 kg
