Haas Mini Mill 2 Vertical Machining Centre
Haas Mini Mill 2 Specifications
X Axis 20 "  508 mm
Z Axis 14 "  356 mm
Spindle Nose to Table (~ min) 4.0 "  102 mm
Spindle Nose to Table (~ max) 18.0 "  457 mm
Length 40 "  1016 mm
Width 14 "  356 mm
T-Slot Center Distance 4.9 "  125 mm
Max Weight on Table (evenly distributed) 500 lb  227 kg
Max Torque 33 ft-lb @ 1200 rpm  45 Nm @ 1200 rpm
Taper CT/40 or BT/40   CT/40 or BT/40
Bearing Lubrication Grease Packed   Grease Packed
Rapids on X 600 in/min  15.2 m/min
Rapids on Y 600 in/min  15.2 m/min
Rapids on Z 600 in/min  15.2 m/min
Tool-to-Tool (avg) 3.6 sec  3.6 sec
Chip-to-Chip (avg) 5.0 sec  5.0 sec
Coolant Capacity 24 gal  91 L
Machine Weight 4000 lb  1814 kg
