THE NEXT GENERATION COMPACT 40-TAPER MACHINE
£19,995
NEXT GENERATION COMPACT MACHINE
19995
Configure yours from £19,995
The USA-made MODULAR MINI MILL packs 40-taper performance into a small footprint CNC machine and features all you need to start cutting metal - from just £19,995.
The Modular Mini Mill is the next step in the evolution of Haas Automation's original compact machine.
Start-Up or Free-Up
They are perfect for schools, start-up companies, or as a first step into CNC machining and are valuable additions for workshops needing a “second-op” machine, or an additional spindle where space is limited.
Add bolt-on option modules, for more flexibility, from just £995.
The USA-made MODULAR MINI MILL packs 40-taper performance into a compact CNC machine and features all you need to start cutting metal - from just £19,995.
MMM options spread
MMM split 424242
LOW COST, BOLT-ON OPTION MODULES
Add bolt-on option modules to increase your flexibility - from just £995.
The low-cost, performance enhancing modules can be retro-fitted at a later date, if you decide you'd like even more flexibility as your business grows.
You can add a coolant pump, a faster spindle and increased rapids, or you could choose the high-productivity software module, or add a 4-axis drive to run a rotary table, perhaps go ‘all out’ and add all available modular options.
coolant module
Coolant Module
£995
Prevent wear, prolong tool life, clear away swarf and achieve better finishes with the coolant module
software module
Software Module
£2,495
Increase your flexibility with Macros, Spindle Orientation, WiFi, Rigid Tapping, Visual Programming, Coordinate Rotation & Scaling
Production module
Production Module
£1,990
Reduce cycle times and boost your production: upgrade to a 6,000 rpm spindle and 15.2 m/min rapids
4-Axis Module
4-Axis Module
£2,045
With the Haas 4-axis drive you can add a rotary table or indexing unit to your Modular Mini Mill
LOW-COST OPTION MODULES
coolant module
Coolant Module
£995
software module
Software Module
£2,495
Production module
Production Module
£1,990
4-Axis Module
4-Axis Module
£2,045
WHAT A MODULAR MINI MILL CAN DO FOR YOU
Start Up
START-UP
If you’re starting-up a new business the Modular Mini Mill is the perfect machine for you
Free Up
FREE-UP
Free-up existing, more expensive machinery to improve your efficiency and boost your productivity
Second-Op
SECOND-OP
The compact Modular Mini Mills are valuable additions when you need a second-op machine, or an extra spindle, where space is limited
Build Up
BUILD-UP
Add Modular Mini Mills to increase your production capacity and support your business expansion
Start Up
START-UP
Free Up
FREE-UP
Second-Op
SECOND-OP
Build Up
BUILD-UP
EVERYTHING YOU NEED TO GET STARTED FOR JUST £19,995
Machine performance once was paired with size and cost. The Mini Mill Series changed everything, by packing 40-taper performance into small packages at unheard of prices.
Since creating the original concept and then building the world’s first Mini Mill in 2000, Haas Automation has installed 13,795 around the globe, with 950 in the UK.
Modular Mini Mills are the next step in the evolution of the genre and have everything needed to cut metal for just £19,995
They are perfect for schools, start-up companies, or as a first step into CNC machining and are valuable additions for workshops needing a “second-op” machine or an additional spindle where space is limited.
START-UP FOR JUST £19,995
MMM hero base model blk-white
MMM hero split mobile
 • 406 x 305 x 254 mm Travels
 • 10-Tool Automatic Changer
 • Standard 40-Taper Tooling
 • 4,000-rpm Vector Drive Spindle
 • 7.6 m/min Rapids
 • Full 12 Month Warranty
7.6 m/min Rapids
Modular Mini Mill Specifications
Retro fit
Retro-fit Modules
Retro-fit modules at a later date if you decide you’d like your machine to have even more flexibility. The modular nature of the machine enables it to grow with your business.
button
FREE Training
As part of every new machine installation, we provide FREE machine orientation and operator training. You can decide whether to have this on-site at your premises, or at one of our training centres, for example the Haas F1 Team Facility in Banbury, Oxfordshire.
ALSO AVAILABLE IN THE MINI MILL RANGE
Haas Automation’s Mini Mills provide a generous work envelope. Handling small-parts manufacturing with the same reliability you’ve come to expect from all Haas CNC machines - they’re ideal for finishing work and cutting aluminium, yet also provide enough low-end torque to cut steel.
sminimill_card
Super Mini Mill
• 10,000 rpm (15K Opt.)
• 40-Taper
• 15 hp
• 30.5 m/min Rapids
Super Mini Mill Details
MINIMILL2_card
Mini Mill 2
• 508 x 406 x 356 mm
• 6,000 rpm Spindle
• 40-Taper
• 7.5 hp
• 15.2 m/min Rapids
Mini Mill 2 Details
SMINIMILL2_card
Super Mini Mill 2
• 40-Taper
• 15 hp
• 30.5 m/min Rapids
Super Mini Mill 2 Details
CM-1_card
Compact Mill
• 305 x 254 x 305 mm
• 30,000 rpm Spindle
• 20-Taper
• 5 hp
• 19.2 m/min Rapids
Compact Mill Details
HIGH-SPEED COMPACT MACHINING CENTRES
The DM and DT series compact, high-speed machining centres are built from proven Haas components and designs.
With their standard 15,000 rpm spindles, 61 m/min rapids, high axis accelerations (1G) and 1.8 second tool change times, they can reduce cycle times by more than 20% compared to the already fast Super Speed Haas VF-2SS.
DT-1_card
Drill/Tap DT-1
• 508 x 406 x 394 mm
• 15,000 rpm Spindle
• 30-Taper
• 20+1 SMTC
• Rigid Tap up to 5,000 rpm
• 61.0 m/min Rapids
DT-1 Details
DT-2_card
Drill/Tap DT-2
• 711 x 406 x 394mm
• 30-Taper
• 20+1 SMTC
• 61.0 m/min Rapids
DT-2 Details
DM-1_card
Drill/Mill DM-1
• 508 x 406 x 394mm
• 40-Taper
• 18+1 SMTC
• 61.0 m/min Rapids
DM-1 Details
DM-2_card
Drill/Mill DM-2
• 711 x 406 x 394mm
• 40-Taper
• 18+1 SMTC
• 61.0 m/min Rapids
DM-2 Details
SEND ME DETAILS OF THE MODULAR MINI MILL
EMAIL ME DETAILS
