Haas Super Mini Mill Vertical Machining Centre
Haas Super Mini Mill Specifications
X Axis 16 "  406 mm
Y Axis 12 "  305 mm
Z Axis 10 "  254 mm
Spindle Nose to Table (~ max) 14 "  356 mm
Length 36 "  914 mm
Length (Work Area) 28.75 "  730 mm
Width 12 "  305 mm
T-Slot Center Distance 4.33 "  110.0 mm
Max Weight on Table (evenly distributed) 500 lb  227 kg
Max Speed 10000 rpm  10000 rpm
Max Torque 17 ft-lb @ 4600 rpm  23 Nm @ 4600 rpm
Rapids on X 1200 in/min  30.5 m/min
Rapids on Y 1200 in/min  30.5 m/min
Max Cutting 833 in/min  21.2 m/min
Capacity 10   10
Tool-to-Tool (avg) 3.0 sec  3.0 sec
Chip-to-Chip (avg) 3.8 sec  3.8 sec
Coolant Capacity 24 gal  91 L
Machine Weight 3400 lb  1542 kg
