Haas Super Mini Mill 2 Vertical Machining Centre
Haas Super Mini Mill 2 Specifications
X Axis 20 "  508 mm
Z Axis 14 "  356 mm
Spindle Nose to Table (~ min) 4.0 "  102 mm
Spindle Nose to Table (~ max) 18.0 "  457 mm
Length 40 "  1016 mm
Width 14 "  356 mm
T-Slot Center Distance 4.9 "  125 mm
Max Weight on Table (evenly distributed) 500 lb  227 kg
Max Speed 10000 rpm  10000 rpm
Max Torque 17 ft-lb @ 4600 rpm  23 Nm @ 4600 rpm
Taper CT/40 or BT/40   CT/40 or BT/40
Rapids on X 1200 in/min  30.5 m/min
Rapids on Y 1200 in/min  30.5 m/min
Max Cutting 833 in/min  21.2 m/min
Capacity 10   10
Tool-to-Tool (avg) 3.0 sec  3.0 sec
Chip-to-Chip (avg) 3.8 sec  3.8 sec
Coolant Capacity 24 gal  91 L
Machine Weight 4000 lb  1814 kg
