Haas ST-10 CNC Turning Centre
Haas ST-10 Specifications
Over Front Apron 25.25 "  641 mm
Over Cross Slide 16.25  "  413 mm
Over Tailstock 23.50 "  597 mm
Chuck Size 6.5 "  165 mm
Max Cutting Diameter 14.0 "  356 mm
Max Cutting Length 14.0 "  356 mm
Bar Capacity 1.75 "  45 mm
X Axis 7.88 "  200.2 mm
Z Axis 14 "  356 mm
Rapids on X 1200 in/min  30.5 m/min
Max Thrust X 3300 lb  14679 N
Max Thrust Z 3300 lb  14679 N
Max Torque 75 ft-lb @ 1300 rpm  102 Nm @ 1300 rpm
Spindle Nose A2-5   A2-5
OD vs ID Tools Any Combination (will vary with turret style)   Any Combination (will vary with turret style)
Boring Bar Rear Clearance (from back of turret ) 0.75 "  19.1 mm
Coolant Capacity 30 gal  114 L
Machine Weight 5000 lb  2268 kg
