Haas ST-10Y Y-axis CNC Turning Centre
Haas ST-10Y Specifications
SWING DIAMETER S.A.E. METRIC
Over Front Apron 25.25 "  641 mm
Over Cross Slide 16.25 "  413 mm
Over Tailstock 23.5 "  597 mm
CAPACITIES S.A.E. METRIC
Chuck Size 6.5 "  165 mm
Max Cutting Diameter (varies with turret) 12 "  305 mm
Max Cutting Length (without workholding) 14.0 "  356 mm
Bar Capacity 1.75 "  44 mm
TRAVELS & FEEDRATES S.A.E. METRIC
X Axis 7.88 "  200 mm
Y Axis ±2 "  ±51 mm
Z Axis 14 "  356 mm
Rapids on X 472 in/min  12 m/min
Rapids on Y 472 in/min  12 m/min
Max Thrust X 2400 lb  10676 N
Max Thrust Y 2300 lb  10231 N
Max Thrust Z 3700 lb  16458 N
Max Torque 75 ft-lb @ 1300 rpm  102 Nm @ 1300 rpm
Spindle Nose A2-5   A2-5
Spindle Bore ø 2.31 "  58.7 mm
Draw Tube Bore ø 1.81 "  46.0 mm
MAIN SPINDLE C AXIS S.A.E. METRIC
Positioning (±) 0.01 °  0.01 °
Brake Clamp Force 1000 lb  4448 N
Control Type Interpolated Motion and Control   Interpolated Motion and Control
TURRET S.A.E. METRIC
OD vs ID Tools Hybrid 6 BOT/6 VDI   Hybrid 6 BOT/6 VDI
Boring Bar Rear Clearance (from back of turret ) 0.75 "  19.1 mm
LIVE TOOLING S.A.E. METRIC
Tooling VDI40   VDI40
Coolant Capacity 15 gal  57 L
