Haas ST-15 CNC Turning Centre
Haas ST-15 Specifications
SWING DIAMETER S.A.E. METRIC
Over Front Apron 27 "  686 mm
Over Cross Slide 16 "  406 mm
Over Tailstock 27 "  686 mm
CAPACITIES S.A.E. METRIC
Max Cutting Diameter (varies with turret) 14.0 "  356 mm
Max Cutting Length (without workholding) 16.0 "  406 mm
Bar Capacity 2.5 "  63.5 mm
TRAVELS & FEEDRATES S.A.E. METRIC
X Axis 7.88 "  200.2 mm
Rapids on X 1200 in/min  30.5 m/min
Max Thrust X 3300 lb  14679 N
Max Thrust Z 3300 lb  14679 N
Max Rating 20 hp  14.9 kW
Max Torque 150 ft-lb @ 500 rpm  203 Nm @ 500 rpm
Spindle Bore ø 3.50 "  88.9 mm
TURRET S.A.E. METRIC
Number of Tools 12 Station BOT   12 Station BOT
OD vs ID Tools Any Combination (will vary with turret style)   Any Combination (will vary with turret style)
Boring Bar Rear Clearance (from back of turret ) 0.75 "  19.1 mm
Coolant Capacity 30 gal  114 L
