Haas ST-15Y Y-Axis CNC Turning Centre
Haas ST-15Y Specifications
SWING DIAMETER S.A.E. METRIC
Over Front Apron 27 "  686 mm
Over Cross Slide 16 "  406 mm
Over Tailstock 27 "  686 mm
CAPACITIES S.A.E. METRIC
Max Cutting Diameter (varies with turret) 12 "  305 mm
Max Cutting Length (without workholding) 16 "  406 mm
Bar Capacity 2.5 "  63.5 mm
TRAVELS & FEEDRATES S.A.E. METRIC
X Axis 7.88 "  200 mm
Y Axis ±2 "  ±51 mm
Rapids on X 472 in/min  12 m/min
Rapids on Y 472 in/min  12 m/min
Max Thrust X 2400 lb  10676 N
Max Thrust Y 2300 lb  10231 N
Max Thrust Z 3700 lb  16458 N
Max Rating 20 hp  14.9 kW
Max Torque 150 ft-lb @ 500 rpm  203 Nm @ 500 rpm
Spindle Bore ø 3.50 "  88.9 mm
MAIN SPINDLE C AXIS S.A.E. METRIC
Positioning (±) 0.02° / 72 arc-sec °  0.02° / 72 arc-sec °
Max Speed 60 rpm, 360°/sec   60 rpm, 360°/sec
Brake Clamp Force 1000 lb  4448 N
Control Type Interpolated Motion and Positioning   Interpolated Motion and Positioning
Brake Holding Torque 140 ft-lb   190 Nm
TAILSTOCK S.A.E. METRIC
Manual Body Positioning 20.0 "  508 mm
Hydraulic Quill Travel 3.75 "  95 mm
Max Thrust (Hyd. Quill Only) 1130 lb  5027 N
Min Thrust (Hyd. Quill Only) 140 lb  623 N
TURRET S.A.E. METRIC
Number of Tools 12 Station (6 VDI; 6 BOT) Hybrid   12 Station (6 VDI; 6 BOT) Hybrid
Boring Bar Rear Clearance (from back of turret ) 0.75 "  19.1 mm
LIVE TOOLING S.A.E. METRIC
Tooling VDI40   VDI40
Coolant Capacity 30 gal  114 L
Coolant Flow Rate 5 gpm @ 28 psi   19 L/min @ 28 psi
