Haas ST-20 CNC Turning Centre
Haas ST-20 Specifications
Max Cutting Diameter 15.0 "  381 mm
Max Cutting Length 21 "  533 mm
Bar Capacity 2.0 "  51 mm
X Axis 9.3 "  236 mm
Z Axis 21.0 "  533 mm
Rapids on X 945 in/min  24.0 m/min
Rapids on Z 945 in/min  24.0 m/min
Max Thrust Z 5100 lb  22686 N
Max Rating 20 hp  14.9 kW
Max Torque 150 ft-lb @ 500 rpm  203 Nm @ 500 rpm
Spindle Bore ø 3.50 "  88.9 mm
OD vs ID Tools Any Combination (will vary with turret style)   Any Combination (will vary with turret style)
Coolant Capacity 48 gal  182 L
Machine Weight 9000 lb  4082 kg
