Haas ST-20SS CNC Turning Centre
Haas ST-20SS Specifications
Max Cutting Diameter 10.0 "  254 mm
Max Cutting Length 21 "  533 mm
Bar Capacity 2.0 "  51 mm
X Axis 9.3 "  236 mm
Z Axis 21.0 "  533 mm
Rapids on X 945 in/min  24.0 m/min
Max Thrust Z 4050 lb  18015 N
Max Speed 5000 rpm  5000 rpm
Max Torque 140 ft-lb @ 1450 rpm  190 Nm @ 1450 rpm
Number of Tools 24 Stations   24 Stations
OD vs ID Tools Hybrid 12 BOT/12 VDI   Hybrid 12 BOT/12 VDI
Coolant Capacity 48 gal  182 L
Machine Weight 9000 lb  4082 kg
