Haas ST-20SSY Super Speed Y-axis CNC Turning Centre
Haas ST-20SSY Specifications
Max Cutting Diameter 10.0 "  254 mm
Max Cutting Length 21 "  533 mm
Bar Capacity 2.0 "  51 mm
X Axis 9.3 "  236 mm
Y Axis ­±2 "  ±50.8 mm
Z Axis 21.0 "  533 mm
Rapids on X 472 in/min  12 m/min
Rapids on Y 472 in/min  12 m/min
Max Thrust Y 2300 lb  10231 N
Max Thrust Z 4050 lb  18015 N
Max Speed 5000 rpm  5000 rpm
Max Torque 140 ft-lb @ 1450 rpm  190 Nm @ 1450 rpm
MAIN SPINDLE C AXIS S.A.E. Metric
Positioning (±) 0.01 °  0.01 °
Brake Clamp Force 1000 lb  4448 Nm
Control Type Interpolated Motion and Control   Interpolated Motion and Control
Number of Tools 24 Stations   24 Stations
OD vs ID Tools Hybrid 12 BOT/12 VDI   Hybrid 12 BOT/12 VDI
LIVE TOOLING S.A.E. Metric
Max Speed 0-3000 rpm  0-3000 rpm
Torque (peak) 195 in-lb  22.03 Nm
Torque (continuous) 75 in-lb  8.47 Nm
Tooling VDI40   VDI40
Coolant Capacity 48 gal  182 L
Machine Weight 9000 lb  4082 kg
