Haas ST-20Y Y-axis CNC Turning Centre
Haas ST-20Y Specifications
Max Cutting Diameter 12.0 "  305 mm
Max Cutting Length 21 "  533 mm
Bar Capacity 2.0 "  51 mm
X Axis 9.3 "  236 mm
Y Axis ±­­­2.00 "  ±50.8 mm
Z Axis 21.0 "  533 mm
Rapids on X 472 in/min  12 m/min
Rapids on Y 472 in/min  12 m/min
Rapids on Z 945 in/min  24.0 m/min
Max Thrust Y 2300 lb  10231 N
Max Thrust Z 5100 lb  22686 N
Max Rating 20 hp  14.9 kW
Max Torque 150 ft-lb @ 500 rpm  203 Nm @ 500 rpm
MAIN SPINDLE C AXIS S.A.E. Metric
Positioning (±) 0.01 °  0.01 °
Brake Clamp Force 1000 lb  4448 N
Control Type Interpolated Motion and Control   Interpolated Motion and Control
OD vs ID Tools Hybrid 6 BOT/6 VDI (will vary with turret style)   Hybrid 6 BOT/6 VDI (will vary with turret style)ill vary with turret style)
LIVE TOOLING S.A.E. Metric
Max Speed 0-3000 rpm  0-3000 rpm
Torque (peak) 195 in-lb  22.03 Nm
Torque (continuous) 75 in-lb  8.47 Nm
Tooling VDI40   VDI40
Coolant Capacity 48 gal  182 L
Machine Weight 9000 lb  4082 kg
