Haas ST-30 CNC Turning Centre
Haas ST-30 Specifications
Chuck Size 10.0 "  254 mm
Max Cutting Diameter 21.0 "  533 mm
Max Cutting Length 26.0 "  660 mm
Bar Capacity 3.0 "  76 mm
Between Centers 30 "  762 mm
X Axis 12.5 "  318 mm
Z Axis 26 "  660 mm
Rapids on X 945 in/min  24.0 m/min
Rapids on Z 945 in/min  24.0 m/min
Max Thrust Z 5100 lb  22686 N
Max Speed 3400 rpm  3400 rpm
Max Torque 300 ft-lb @ 500 rpm  407 Nm @ 500 rpm
Max Torque w/opt Gearbox 1000 ft-lb @ 150 rpm  1356 Nm @ 150 rpm
OD vs ID Tools Any Combination (will vary with turret style)   Any Combination (will vary with turret style)
Machine Weight 13200 lb  5988 kg
