Haas ST-30SS CNC Turning Centre
Haas ST-30SS Specifications
Chuck Size 10.0 "  254 mm
Max Cutting Diameter 16.0 "  406 mm
Max Cutting Length 26.0 "  660 mm
Bar Capacity 3.0 "  76 mm
X Axis 12.5 "  318 mm
Z Axis 26 "  660 mm
Rapids on X 945 in/min  24.0 m/min
Max Thrust Z 4050 lb  18015 N
Max Rating 30 hp  22 kW
Max Speed 4500 rpm  4500 rpm
Max Torque 275 ft-lb @ 600 rpm  373 Nm @ 600 rpm
Number of Tools 24 Stations   24 Stations
OD vs ID Tools Hybrid 12 BOT/12 VDI   Hybrid 12 BOT/12 VDI
Machine Weight 13300 lb  6033 kg
