Haas ST-30SSY Super Speed Y-axis CNC Turning Centre
Haas ST-30SSY Specifications
Chuck Size 10.0 "  254 mm
Max Cutting Diameter 16.0 "  406 mm
Max Cutting Length 23 "  584 mm
Bar Capacity 3.0 "  76 mm
X Axis 12.5 "  318 mm
Y Axis ±2.0 "  ±51 mm
Z Axis 23 "  584 mm
Rapids on X 472 in/min  12 m/min
Rapids on Y 472 in/min  12 m/min
Max Thrust Y 2300 lb  10231 N
Max Thrust Z 4050 lb  18015 N
Max Rating 30 hp  22 kW
Max Speed 4500 rpm  4500 rpm
Max Torque 275 ft-lb @ 600 rpm  373 Nm @ 600 rpm
MAIN SPINDLE C AXIS S.A.E. Metric
Positioning (±) 0.01 °  0.01 °
Brake Clamp Force 1000 lb  4448 N
Control Type Interpolated Motion & Positioning   Interpolated Motion & Positioning
Number of Tools 24 Stations   24 Stations
OD vs ID Tools Hybrid 12 BOT/12 VDI   Hybrid 12 BOT/12 VDI
LIVE TOOLING S.A.E. Metric
Max Speed 0-3000 rpm  0-3000 rpm
Torque (peak) 195 in-lb  22.03 Nm
Torque (continuous) 75 in-lb  8.47 Nm
Tooling VDI40   VDI40
Machine Weight 13540 lb  6142 kg
