Haas ST-30Y Y-axis CNC Turning Centre
Haas ST-30Y Specifications
Chuck Size 10.0 "  254 mm
Max Cutting Diameter 18.0 "  457 mm
Max Cutting Length 23 "  584 mm
Bar Capacity 3.0 "  76 mm
Between Centers 30 "  762 mm
X Axis 12.5 "  318 mm
Y Axis ±2.00 "  ±50.8 mm
Z Axis 23 "  584 mm
Rapids on X 472 in/min  12 m/min
Rapids on Y 472 in/min  12 m/min
Rapids on Z 945 in/min  24.0 m/min
Max Thrust Y 2300 lb  10231 N
Max Thrust Z 5100 lb  22686 N
Max Speed 3400 rpm  3400 rpm
Max Torque 300 ft-lb @ 500 rpm  407 Nm @ 500 rpm
Max Torque w/opt Gearbox 1000 ft-lb @150 rpm  1356 Nm @ 150 rpm
MAIN SPINDLE C AXIS S.A.E. Metric
Positioning (±) 0.01 °  0.01 °
Brake Clamp Force 1000 lb  4448 N
Control Type Interpolated Motion & Positioning   Interpolated Motion & Positioning
OD vs ID Tools Hybrid 6 BOT/6 VDI (will vary with turret style)   Hybrid 6 BOT/6 VDI (will vary with turret style)
LIVE TOOLING S.A.E. Metric
Max Speed 0-3000 rpm  0-3000 rpm
Torque (peak) 195 in-lb  22.03 Nm
Torque (continuous) 75 in-lb  8.47 Nm
Tooling VDI40   VDI40
Machine Weight 14860 lb  6741 kg
