Haas ST-40 CNC Turning Centre
Haas ST-40 Specifications
Over Front Apron 34.5 "  876 mm
Over Cross Slide 25.5 "  648 mm
Over Tailstock 25.5 "  648 mm
Chuck Size 15 "  381 mm
Max Cutting Diameter 25.5 "  648 mm
Max Cutting Length 44 "  1118 mm
Bar Capacity 4.0 "  102 mm
X Axis 17 "  432 mm
Z Axis 44 "  1118 mm
Rapids on X 710 in/min  18.0 m/min
Rapids on Z 710 in/min  18.0 m/min
Max Thrust X 5500 lb  24465 N
Max Thrust Z 9000 lb  40034 N
Max Rating 40 hp  29.8 kW
Max Speed 2400 rpm  2400 rpm
Max Torque 1400 ft-lb @ 150 rpm  1898 Nm @ 150 rpm
Spindle Nose A2-8   A2-8
SPINDLE (OPT) S.A.E. Metric
Max Rating 55 hp  41 kW
Max Torque 2100 ft-lb @ 150 rpm  2847 Nm @ 150 rpm
OD vs ID Tools Any Combination (will vary with turret style)   Any Combination (will vary with turret style)
Boring Bar Rear Clearance (from back of turret ) 4.37 "  111 mm
Coolant Capacity 90 gal  341 L
Machine Weight 27000 lb  12247 kg
Haas ST-40L Long Bed Specifications
ST-40L
SWING DIAMETER S.A.E. METRIC
CAPACITIES S.A.E. METRIC
Max Cutting Length 80 "  2032 mm
TRAVELS & FEEDRATES S.A.E. METRIC
X Axis 17 "  432 mm
Z Axis 80 "  2032 mm
Rapids on Z 320 in/min  8.1 m/min
Spindle Bore ø 4.62 "  117.3 mm
SPINDLE (OPT) S.A.E. METRIC
Max Thrust Z 6750 lb  30025 N
TURRET S.A.E. METRIC
Coolant Capacity 120 gal  454 L
Machine Weight 30000 lb  13608 kg
