Haas T5C-2 Tilting Multi-axis Indexing UnitHaas CNC machine tools, CNC mills and CNC lathes
Haas T5C-2 Specifications
SPINDLE – A (TILT) S.A.E. METRIC
Max Speed 0.001 to 60 °/sec  0.001 to 60 °/sec
Max Torque 210 ft-lb  285 Nm
Center Height 6.000 ±0.001 "  152.40 ±0.03 mm
Gear Ratio 90:1    90:1
SPINDLE – B (ROTARY) S.A.E. METRIC
Number 2   2
Max Speed 0.001 to 200 °/sec  0.001 to 200 °/sec
Max Torque 25 ft-lb  34 Nm
Nose Thread 2 3/16" - 10
Runout Max 0.0004 "  0.010 mm
Backlash 50 arc-sec   50 arc-sec
Center Height 6.000 ± 0.001 "  152.40 ± 0.03 mm
Gear Ratio 60:1    60:1
Collet size std 5C (1/64 - 1 1/16) "  std 5C (0.4 - 27) mm
INDEXING – A (TILT) S.A.E. METRIC
Max Rotation/Step ±120 °  ±120 °
Worm Gear Dia 6.3 "  160 mm
INDEXING – B (ROTARY) S.A.E. METRIC
Accuracy (±) 60 arc-sec   60 arc-sec
Worm Gear Dia 2.8 "  71 mm
GENERAL – A (TILT) S.A.E. METRIC
Power Required – 1-Axis Control 115 VAC ± 10% @ 15 A   115 VAC ± 10% @ 15 A
GENERAL – B (ROTARY) S.A.E. METRIC
Duty Cycle full/low speed 75% full speed   75% full speed
Table 370  lb  168 kg
Brushless Control – 1-Axis 14.2  lb  6.4 kg
