Haas TL-2 CNC Toolroom Lathe
Haas TL-2 Specifications
TL-2
SWING DIAMETER S.A.E. METRIC
Over Front Apron 20 "  508 mm
Over Cross Slide 11 "  279 mm
CAPACITIES S.A.E. METRIC
Chuck (optional) 8 "  203 mm
Max Cutting Diameter (varies with turret) 16 "  406 mm
Max Cutting Length (without workholding) 48 "  1219 mm
Between Centers 48 "  1219 mm
TRAVELS & FEEDRATES S.A.E. METRIC
X Axis 8 "  203 mm
Z Axis 48 "  1219 mm
Rapids on X 450 in/min  11.4 m/min
Rapids on Z 450 in/min  11.4 m/min
Max Thrust X 3894 lb  17 321 N
Max Thrust Z 1947 lb  8661 N
Max Rating 10 hp  8.9 kW
Max Speed 1,800 rpm  1,800 rpm
Max Torque 108 ft-lb @ 355 rpm  146 Nm @ 355 rpm
Spindle Bore ø 3.00 "  76.2 mm
SPINDLE (OPT) S.A.E. METRIC
Max Rating 12 hp  7.5 kW
Max Speed 3000 rpm  3000 rpm
