Haas TM-1 CNC Toolroom Mill
Haas TM-1 Specifications
X Axis 30 "  762 mm
Y Axis 12 "  305 mm
Spindle Nose to Table (~ max) 20 "  508 mm
Length 47.75 "  1213 mm
Width 10.5 "  267 mm
T-Slot Center Distance 4.00 "  101.6 mm
Max Weight on Table (evenly distributed) 1000 lb  454 kg
Max Torque 33 ft-lb @ 1200 rpm  45 Nm @ 1200 rpm
Bearing Lubrication Grease packed   Grease packed
Rapids on X 200 in/min  5.1 m/min
Rapids on Y 200 in/min  5.1 m/min
Rapids on Z 200 in/min  5.1 m/min
Max Cutting 200 in/min  5.1 m/min
Machine Weight 3240 lb  1470 kg
Click for CNC machines
