Haas TM-2 CNC Toolroom Mill
Haas TM-2 Specifications
X Axis 40 "  1016 mm
Spindle Nose to Table (~ max) 20 "  508 mm
Length 57.75 "  1466.9 mm
Width 10.5 "  267 mm
T-Slot Center Distance 4.00 "  101.6 mm
Max Weight on Table (evenly distributed) 1000 lb  454 kg
Max Torque 33 ft-lb @ 1200 rpm  45 Nm @ 1200 rpm
Drive System Direct Speed, Belt Drive   Direct Speed, Belt Drive
Bearing Lubrication Grease packed   Grease packed
Rapids on X 200 in/min  5.1 m/min
Rapids on Y 200 in/min  5.1 m/min
Rapids on Z 200 in/min  5.1 m/min
Max Cutting 200 in/min  5.1 m/min
Machine Weight 4280 lb  1941 kg
