Haas TM-2P CNC Toolroom Mill
Haas TM-2P Specifications
X Axis 40 "  1016 mm
Spindle Nose to Table (~ max) 20 "  508 mm
TABLE S.A.E. METRIC
Length 57.75 "  1466 mm
Width 10.5 "  267 mm
T-Slot Center Distance 4.00 "  101.6 mm
Max Weight on Table (evenly distributed) 1000 lb  454 kg evenly distributed
Max Torque 33 ft-lb @ 1200 rpm  45 Nm @1200 rpm
Bearing Lubrication Grease packed   Grease packed
Rapids on X 400 in/min  10.2 m/min
Rapids on Y 400 in/min  10.2 m/min
Rapids on Z 400 in/min  10.2 m/min
Max Cutting 400 in/min  10.2 m/min
Capacity 10   10
Tool-to-Tool (avg) 5.7 sec  5.7 sec
Chip-to-Chip (avg) 6.5 sec  6.5 sec
