Haas TM-3P CNC Toolroom Mill
Haas TM-3P Specifications
X Axis 40 "  1016 mm
Y Axis 20 "  508 mm
Spindle Nose to Table (~ max) 20 "  508 mm
Length 57.75 "  1467 mm
Width 14.5 "  368 mm
Max Weight on Table (evenly distributed) 1000 lb  454 kg
Max Torque 33 ft-lb @ 1200 rpm  45 Nm @ 1200 rpm
Drive System Direct Speed, Belt Drive   Direct Speed, Belt Drive
Bearing Lubrication Grease packed   Grease packed
Rapids on X 400 in/min  10.2 m/min
Rapids on Y 400  in/min  10.2 m/min
Rapids on Z 400  in/min  10.2 m/min
Max Cutting 400 in/min  10.2 m/min
Type Carousel    Carousel
Capacity 10   10
Max Tool Diameter (full) 3.5  "  89 mm
Max Tool Weight 12  lb  5.4 kg
Tool-to-Tool (avg) 5.7  sec  5.7 sec
Chip-to-Chip (avg) 6.5 sec  6.5 sec
Machine Weight 5780 lb  2622 kg
