Haas Magazine
Haas TR-160-2 Twin Spindle Trunnion Table SpecificationsHaas CNC machine tools, CNC mills and CNC lathes
Platter Diameter 6.30 "  160 mm
Part Swing Max 10.45 "  265.4 mm
SPINDLE – A (TILT) S.A.E. METRIC
Max Speed 0.001 to 80 °/sec  0.001 to 80 °/sec
Max Torque 150 ft-lb  203 Nm
Gear Ratio 63:1    63:1
SPINDLE – B (ROTARY) S.A.E. METRIC
Number 2   2
Max Torque 100 ft-lb  136 Nm
Pilot Bore Dia. (through) 1.500 (+0.0005, -0) "  38.10 (+0.013, -0) mm
Brake Torque @ 100 psi/6.9 bar 100 ft-lb  136 Nm
INDEXING – A (TILT) S.A.E. METRIC
Max Rotation/Step 120 °  120 °
INDEXING – B (ROTARY) S.A.E. METRIC
Duty Cycle full/low speed 50/100  %  50/100 %
Power Required – 1-Axis Control 115 VAC ±10% @ 15 A    115 VAC ±10% @ 15 A
Table 478 lb  217 kg
Brushless Control – 1-Axis 14.2 lb  6.4 kg
