Haas TRT-160 Tilting Table SpecificationsHaas CNC machine tools, CNC mills and CNC lathes
Diameter 6.3 "  160 mm
SPINDLE – A (TILT) S.A.E. METRIC
Max Speed 0.001 to 60 °/sec  0.001 to 60 °/sec
Max Torque 210 ft-lb  285 Nm
Runout Max 0.0005 "  0.013 mm (reduced at tilt angles > ±90°)
Center Height 7.750 ± 0.001 "  196.85 ± 0.03 mm
Gear Ratio 63:1    63:1
SPINDLE – B (ROTARY) S.A.E. METRIC
Max Speed 0.001 to 80 °/sec  0.001 to 80 °/sec
Max Torque 150 ft-lb  203 Nm
Gear Ratio 90:1    90:1
Brake Torque @ 100 psi/6.9 bar 100 ft-lb  136 Nm
INDEXING – A (TILT) S.A.E. METRIC
Max Rotation/Step 120 °  120 °
Accuracy (±) 25 arc-sec   25 arc-sec
INDEXING – B (ROTARY) S.A.E. METRIC
Power Required – 1-Axis Control 115 VAC ± 10% @ 15 A    115 VAC ± 10% @ 15 A
Table 400 lb  181.4 kg
Brushless Control – 1-Axis 14.2 lb  6.4 kg
