Haas Magazine
Haas TRT-210 Tilting Table Specifications
Diameter 8.3 "  210 mm
SPINDLE – A (TILT) S.A.E. METRIC
Max Speed 0.001 to 50 °/sec  0.001 to 50 °/sec
Max Torque 300 ft-lb  407 Nm
Center Height 9.000 ± 0.001 "  228.60 ± 0.03 mm
Gear Ratio 90:1    90:1
Brake Torque @ 100 psi/6.9 bar 500 ft-lb  678 Nm
SPINDLE – B (ROTARY) S.A.E. METRIC
Max Speed 0.001 to 60 °/sec  0.001 to 60 °/sec
Max Torque 210 ft-lb  285 Nm
Gear Ratio 72:1    72:1
INDEXING – A (TILT) S.A.E. METRIC
Max Rotation/Step 120 °  120 °
Accuracy (±) 25 arc-sec   25 arc-sec
INDEXING – B (ROTARY) S.A.E. METRIC
Power Required – 1-Axis Control 115 VAC ± 10% @ 15 A    115 VAC ± 10% @ 15 A
Table 735 lb  333.4 kg
Brushless Control – 1-Axis 14.2 lb  6.4 kg
