Haas UMC-750 5-Axis Universal Machining Centre
Haas UMC-750 Specifications
X Axis 30 "  762 mm
Y Axis 20 "  508 mm
Z Axis 20 "  508 mm
B Axis Tilt +110° to -35°   +110° to -35°
C Axis Rotation 360 °  360 °
Spindle Nose to Table (~ max) 24 "  610 mm
Platter Diameter 19.7 "  500 mm
Max Weight on Platter 660 lb  300 kg
T-Slot Center Distance 2.48 "  63 mm
Number of Std T-Slots 7   7
SPINDLE 8,100 RPM S.A.E. METRIC
Max Speed 8100 rpm  8100 rpm
Max Torque 90 ft-lb @ 2000 rpm  122 Nm @ 2000 rpm
Drive System Inline Direct-Drive   Inline Direct-Drive
Cooling Air   Air
SPINDLE 12,000 RPM S.A.E. METRIC
Max Speed 12000 rpm  12000 rpm
Cooling Air   Air
Rapids on X 1200 in/min  30.5 m/min
Rapids on Y 1200 in/min  30.5 m/min
Max Cutting 650 in/min  16.5 m/min
FEEDRATES (ROTARY) S.A.E. METRIC
Rapids on B 50 °/sec  50 °/sec
Rapids on C 50 °/sec  50 °/sec
Max Cutting (Rotary) 50 °/sec  50 °/sec
Max Thrust X 2750 lb  12233 N
Max Thrust Y 2750 lb  12233 N
Max Thrust Z 3400 lb  15124 N
Capacity 40+1   40+1
Max Tool Diameter (adjacent empty) 5 "  127 mm
Max Tool Diameter (full) 3 "  76 mm
Max Tool Length (from gage line) 12 "  305 mm
Tool-to-Tool (avg) 2.8 sec  2.8 sec
Chip-to-Chip (avg) 3.6 sec  3.6 sec
Coolant Capacity 75 gal  284 L
