Haas UMC-750SS 5-Axis Universal Machining Centre
Haas UMC-750SS Specifications
X Axis 30 "  762 mm
Y Axis 20 "  508 mm
Z Axis 20 "  508 mm
Spindle Nose to Table (~ max) 24 "  610 mm
Platter Diameter 19.7 "  500 mm
Max Weight on Platter 660 lb  300 kg
T-Slot Center Distance 2.48 "  63 mm
Number of Std T-Slots 7   7
B AXIS – TILT S.A.E. METRIC
Travel +110°, -35°   +110°, -35°
Max Speed 150°/sec   150°/sec
Max Torque 1200 ft-lb  1627 Nm
Brake Torque 4300 ft-lb  5830 Nm
C-AXIS – ROTATION S.A.E. METRIC
Travel 360°   360°
Max Torque 450 ft-lb  407 Nm
Brake Torque 3300 ft-lb  4474 Nm
Max Speed 15000 rpm  15000 rpm
Max Torque 90 ft-lb @ 2000 rpm  122 Nm @ 2000 rpm
Drive System Inline Direct-Drive   Inline Direct-Drive
Cooling Air   Air
Rapids on X 1200 in/min  30.5 m/min
Rapids on Y 1200 in/min  30.5 m/min
Max Cutting 650 in/min  16.5 m/min
Max Thrust X 2750 lb  12233 N
Max Thrust Y 2750 lb  12233 N
Max Thrust Z 3400 lb  15124 N
Capacity 40+1   40+1
Max Tool Diameter (adjacent empty) 5 "  127 mm
Max Tool Diameter (full) 3 "  76 mm
Max Tool Length (from gage line) 12 "  305 mm
Tool-to-Tool (avg) 1.6 sec  1.6 sec
Chip-to-Chip (avg) 2.2 sec  2.2 sec
Coolant Capacity 75 gal  284 L
Click for CNC machines
