Haas VF-10 Vertical Machining Centre
Haas VF-10 Specifications
X Axis 120"  3048 mm
Y Axis 32"  813 mm
Z Axis 30"  762 mm
Spindle Nose to Table (~ max) 34"  864 mm
Length 120"  3048 mm
Width 28"  711 mm
Max Weight on Table (evenly distributed) 4000lb  1814 kg
Rapids on X 360in/min  9.1 m/min
Rapids on Y 600in/min  15.2 m/min
Rapids on Z 600in/min  15.2 m/min
Max Cutting 360in/min  9.1 m/min
Max Thrust Z 5600lb  24910 N
Max Tool Diameter (adjacent empty) 6"  152 mm
Max Tool Length (from gage line) 16"  406 mm
Tool-to-Tool (avg) 2.8sec  2.8 sec
Chip-to-Chip (avg) 3.6sec  3.6 sec
Machine Weight 28000lb  12701 kg
