Haas VF-1YT Vertical Machining Centre
Haas VF-1YT Specifications
X Axis 20"  508 mm
Y Axis 20"  508 mm
Z Axis 20"  508 mm
Spindle Nose to Table (~ max) 24"  610 mm
Length 26"  660 mm
Width 18"  457 mm
Max Weight on Table (evenly distributed) 3000lb  1361 kg
Drive System Direct Speed Belt Drive  Direct Speed Belt Drive
Max Torque w/opt Gearbox 250 ft-lb @450rpm  339 Nm @ 450 rpm
Rapids on X 1000in/min  25.4 m/min
Rapids on Y 1000in/min  25.4 m/min
Rapids on Z 1000in/min  25.4 m/min
Max Cutting 650in/min  16.5 m/min
Max Thrust X 2550lb  11343 N
Max Thrust Y 2550lb  11343 N
Max Thrust Z 4200lb  18683 N
Type Carousel (SMTC Optional)   Carousel (SMTC Optional)
Tool-to-Tool (avg) 4.2sec  4.2 sec
Chip-to-Chip (avg) 4.5sec  4.5 sec
Machine Weight 7400lb  3357 kg
